Document ID: c06562898
Version: 1
ZBook 15 G6 Mobile Workstations - May Not Have SATA Connector
Release date : 13-Feb-2020
Last updated : 13-Feb-2020
DESCRIPTION
If an HP ZBook 15 G6 mobile workstation is configured with NVIDIA® Quadro® RTX3000, the system does not have a SATA connector. Therefore, 2.5 inch Storage Bay Drive cannot be used.
NVIDIA® Quadro® T1000 and T2000 configurations have the SATA connector.
SCOPE
Systems:
  • HP ZBook 15 G6 Mobile Workstation
Operating Systems:
  • Non-OS Specific
RESOLUTION
The configuration is not designed to use SATA HDDs. This is working as designed. Use M.2 SATA SSD or NVMe PCIe SSD instead of SATA HDD.
Hardware platforms affected : HP ZBook 15 G6 Mobile Workstation
Support Communication Cross Reference ID : IA06562898
