    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP DeskJet, ENVY 6000, 6400 Printers - Wireless Printer Setup
This document is for HP DeskJet Plus Ink Advantage 6075, 6078, 6475, 6476, 6478, ENVY 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034e, 6052, 6052e, 6055, 6055e, 6075e, 6420e, 6430e, 6432e, 6452e, 6455e, 6458e, 6475e, ENVY Pro 6420, 6422, 6430, 6432, 6452, 6455, and 6458 All-in-One printers.
Use Wi-Fi Protected Setup (WPS) or HP Smart to establish a wireless connection between your printer and network.
Step 1: Prepare for installation
Make sure your printer is turned on and your mobile device or computer is on the same wireless network you want to connect the printer to.
  1. To use your printer on a wireless network, you need the following items:
    • A compatible computer or mobile device connected to your wireless network
    • Internet access
  2. Make sure the router and computer or mobile device are turned on.
  3. Make sure the computer or mobile device is connected to the same wireless network to which you want to connect the printer.
  4. Set up the printer, load paper into the input tray, and install the ink cartridges. For more information about setting up the printer, go to First Time Printer Setup.
  5. Turn on the printer and place it close to the computer and within range of the router during the setup procedure.
Step 2: Connect the printer to your wireless network
Use WPS or HP Smart to establish a wireless connection between your printer and network.
Use Wi-Fi Direct to make a wireless connection when a wireless network is a guest network or when a wireless network is not available.
If a Find Printer Pin message displays during setup, enter the PIN found on the label adhered to the printer.
Locating the PIN found on the label adhered to the printer
