HP Latex Print and Cut - Knife Blade Comparison
Issue:
What are the knife blades avallable for the HP Print and Cut Solution?
Solution
The HP Print and Cut solution ships with a standard knife blade that is suitable for most Print and Cut projects. This Table lists the features of all 3 blade options supported by the Cutter.
Standard Blade
Speciality Blade
Sandblast Blade
Angle
36 Degrees
60 Degrees
55 Degrees
Holder
Standard Holder
Standard Holder
Sandblast Holder
Media Thickness
Up to 0.25 mm
Up to 0.5mm
Up to 0.8 mm
Included with Cutter
x2 in Box. Availabable as a Consumable
Not included. Available as a Consumable
Not included. Available as an Accessory
Application
Used most of time, Standard Vinyl
Used for Thicker media, Heat transfer and felt
Used for Rubber materials and reflective materials. (NOTE: Class / Grade 2 or higher require a cutting table)
Typical Use
Labels, Decals, Signs: Self-adhesive Vinyl
Textile: Thick Flock and Flex (+ 0.4 mm)
Rhinestone: Sandblast Film
Fridge Decals: Thin Magnetic Foil (Max 0.5mm)
Sandblast Rubber
Traffic signs and Vehicles: Reflective Material
After determining material thickness, decide on knife type based on application:
Summary
The Standard blade will suffice for all Self Adhesive vinyl applications. If the project requires a different media, then consider the other knife options.
