HP Pavilion - 15-cs3017ur Product Specifications
8RR69EA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
Video graphics
  • Intel® UHD Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9461 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 5 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
36.16 x 24.56 x 1.79 cm
1.85 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 45 minutes
B&O; Dual speakers; HP Audio Boost 1.0
