HP DeskJet 2700, DeskJet Plus 4100 Printers - First Time Printer Setup
This document is for the HP DeskJet 2710, 2721e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2732, 2752, 2752e, 2755, 2755e, 4110e, 4120e, 4121e, 4122e, 4123e, 4130e, 4132e, 4152e, 4155e, 4158e, DeskJet Ink Advantage 2775, 2776, 4175, 4176, DeskJet Plus 4110, 4120, 4121, 4122, 4130, 4140, 4152, 4155, and 4158 All-in-One printers.
To set up your printer for the first time, remove all package materials, connect the power cord, install the ink cartridges, and then load paper in the input tray.
If you are looking for the printer software, go to 123.hp.com.
Remove the printer from the box, and then remove all tape, stickers, and package materials from the printer.
  2. Remove all tape and package materials from the outside of the printer.
  3. Lower the output tray, reach inside the printer, and then grasp the handle and lower the ink cartridge access door to open it.
    DeskJet 2700
    DeskJet Plus 4100
    Opening the ink cartridge access door
  4. Remove all tape and package materials from inside the printer.
  5. Make sure you remove all hardware and materials from the box before discarding or recycling the box and package materials.
Step 2: Connect the power cord
Plug the printer into a power source to turn on the printer.
    Connecting the power cord
  2. Press the Power button to turn on the printer.
    The carriage moves to the center of the printer.
  3. Wait until the printer is idle and silent before you continue.
Install the HP ink cartridges that shipped in the box with your printer.
  1. Remove one of the ink cartridges from its package. Be careful to only touch the black plastic on the ink cartridge.
    Removing the ink cartridge from its package
  2. Remove the plastic tape.
    Removing the plastic tape
  3. Slide the cartridge into the slot at a slight upward angle, and then push up on the cartridge until it snaps into place.
    Install the color ink cartridge on the left and the black ink cartridge on the right.
    Snapping the ink  cartridge into place
  4. Close the ink cartridge access door.
    DeskJet 2700
    DeskJet Plus 4100
    Closing the ink cartridge access door
Load plain, U.S. letter or A4 paper in the input tray after you install the ink cartridges.
Step 5: Install the printer software
Download the latest version of the printing software from the following HP website: 123.hp.com.
For print quality purposes, the printer prints an alignment page after three pages are printed. Follow the instructions on the alignment page to complete the ink cartridge alignment.
