    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-rb512ur Product Specifications
9QY39EA
AMD Dual-Core A6-9220 APU (2.5 GHz base frequency, up to 2.9 GHz burst frequency, 1 MB cache)
AMD Integrated SoC
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R4 Graphics
128 GB M.2 SSD
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA anti-glare micro-edge WLED-backlit (1366 x 768)
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.0 combo
1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
38 x 25.38 x 2.38 cm
Starting at 1.86 kg
45 W Smart AC adapter
3-cell, 31 Wh Li-ion
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
