    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion - 15-cw1018ur Product Specifications
8PJ06EA
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
36.16 x 24.56 x 1.79 cm
Starting at 1.85 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Pre-installed software
Netflix (30-day free trial offer)
