    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
OMEN by HP 15-dc1106tx Product Specifications
8US37PA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
36 x 26.3 x 2.6 cm
2.32 kg
150 W AC power adapter
3-cell, 52 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP JumpStart; HP Support Assistant; OMEN Command Center; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
