    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Pavilion - 14-ce3017tx Product Specifications
8MY81PA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2666 SDRAM (1 x 4 GB)
512 GB PCIe® NVMe™ M.2 SSD
14" diagonal FHD IPS BrightView micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
32.68 x 22.55 x 1.79 cm
Starting at 1.6 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP Audio Switch; HP CoolSense; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings; HP BIOS Recovery
Pre-installed software
iQiyi; B&O Audio
