    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Notebook - 15-dw0015nt Product Specifications
8KK57EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8821CE 802.11 b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
1.78 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 8 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
Pre-installed software
Netflix (30-day free trial offer)
