note:HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
- ${title}
- ${title}
- ${title}
- ${title}
HP EliteDesk 800 G5 Small Form Factor PC - Illustrated Parts
Computer major components
Figure : Computer major components illustrated
Item
(1)
Access panel
(2)
Power supply, 250W
(3)
Speaker
(4)
Fan sink (for use in models with a 95 W processor; includes replacement thermal material)
(5)
Fan baffle (for use in models with a 95 W processor)
(6)
Optional rear port (HDMI, VGA, DP or USB-C port)
(7)
Option boards:
VGA option board
USB-C option board
HDMI option board
DisplayPort option board
Thunderbolt 3 option board (uses PCIe slot; not illustrated))
(8)
Rear fan (for use only in models with a 95 W processor)
(9)
WLAN modules
Intel 7265 802.11AC 2x2 with Bluetooth M.2 Combo Card (non-vPro)
Intel 7265 802.11AC 2x2 with Bluetooth M.2 Combo Card (vPro)
Intel Dual Band Wireless-AC 9560 802.11 AC 2x2 WiFi + Bluetooth 5.0 Combo Adapter (vPro)
Intel Dual Band Wireless-AC 9560 802.11 AC 2x2 WiFi + Bluetooth 5.0 Combo Adapter (non-vPro)
Realtek RTL8821CE 802.11 ac 1x1 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
Realtek RTL8822BE 802.11 ac 2x2 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
(10)
Solid-state drives, NVMe, M.2 2280, PCIe
1 TB, TLC
512-GB, TLC
512-GB, self-encrypting drive, TLC
512-GB
256-GB, TLC
256-GB, self-encrypting drive, TLC
256-GB
128-GB, TLC
128-GB
Optane memory module, 16-GB, TLC
(11)
Fan baffle (for use with processors up to 65 W)
(12)
Fan sink (for use with processors up to 65 W; includes replacement thermal material)
(13)
Processor (include replacement thermal material; not illustrated))
Intel Core i7-8700 processor
Intel Core i7-8700K processor
Intel Core i5-8600 processor
Intel Core i5-8600K processor
Intel Core i5-8500 processor
Intel Core i3-8033 processor
Intel Core i3-8011 processor
Intel Pentium G5600 processor
Intel Pentium G5500 processor
Intel Pentium G5400 processor
Intel Celeron G4900 processor
(14)
RTC battery
(15)
Bezel blank, slim optical drive
(16)
Memory module (UDIMM, non-ECC, 1.2v, PC4-2666)
16-GB
8-GB
4-GB
(17)
Front bezel
(18)
System board (includes replacement thermal material)
(19)
Graphics cards (full-height, PCIe x16)
AMD Radeon™ R7 430, 2 GB
AMD Radeon R5 420, 1 GB
AMD Radeon RX580, 4 GB
Nvidia GeForce GTX 1060, 3 GB
NVIDIA Quadro P400 , 2 GB
Intel Ethernet I210-T1 PCIe x1 Gb NIC
Printer port, PCIe x1 card
(20)
SATA data cable, 6 inch, 2 straight ends
SATA data cable, 6 inch, 2 straight ends (RF solution)
SATA data cable, 6 inch, 1 straight end, 1 angled end
SATA data cable, 6 inch, 1 straight end, 1 angled end (RF solution)
(21)
SATA power cable
Antenna, wireless
(22)
Hard drives, 3.5-inch
2-TB, 7200-rpm
2-TB, 5400-rpm, 7 mm
2-TB, 5400-rpm, hybrid SSD, 7 mm
1-TB, 7200-rpm
1-TB, 7200-rpm, 9.5 mm
1-TB, 5400-rpm, hybrid SSD, 9.5 mm
500 GB, 7200 rpm, 7 mm
500-GB, 7200-rpm
500 GB, 7200 rpm, OPAL2, self-encrypting drive (SED), 7 mm
500-GB, 5400-rpm, FIPS, 7 mm
500-GB, 5400-rpm, hybrid SSD, 7 mm
(23)
Bezel dust filter
(24)
Solid-state drives, 2.5-inch, SATA-3, TLC
512-GB, FIPS-140-2
512-GB, OPAL 2, self-encrypting drive (SED)
512-GB
256-GB, FIPS-140-2
256-GB, OPAL 2, self-encrypting drive (SED)
256-GB
(25)
Optical drives, 9.5 mm
DVD Blu-ray-writer
DVD±RW drive
DVD-ROM drive
Stand (not illustrated)
Miscellaneous parts
HP USB-Type C to USB Type-A Hub
SATA drive power cable
DisplayPort cable
DVI monitor cable
Adapters
DisplayPort to VGA
DisplayPort to DVI
DisplayPort to HDMI 2.0
USB Type-C to USB 3.0
USB to serial port
Keyboard
Washable, PVC, USB/PS2
Grey, USB
Smart card, CCID, USB
Smart card, slim, CCID, USB
USB
Conferencing, USB
Slim, PS/2
USB, slim
Wireless keyboard and mouse
Slim, PCR, USB (Brazil and Latin America)
Anti-microbial, slim
Grey, slim, USB
Collaboration, USB
Collaboration, wireless
Wireless, premium
Premium, USB
Health care, wired, USB
Premium, wireless, keyboard and mouse
Mouse
PS/2, optical
USB, optical
USB, laser
USB, premium
USB, antimicrobial
USB/PS2, washable
USB, hardened
USB, grey
USB, heath care, wired
Power cord
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
