HP Elitedesk 705 G4 Microtower PC - Components
Standard configuration features
Features may vary depending on the model. For support assistance and to learn more about the hardware and software installed on your computer model, run the HP Support Assistant utility.
Figure : Standard configuration with computer, monitor, keyboard, and mouse
Front panel components
Drive configuration may vary by model. Some models have a bezel blank covering the slim optical drive bay.
Figure : Identifying the front panel components
1
5.25-inch half-height drive bay (behind bezel)
6
USB 2.0 port (fast charging port)
2
Slim optical drive (optional)
7
USB 2.0 port
3
Power button
8
USB 3.1 Gen 1 ports (2) (5 Gbit/s data speed)
4
Hard drive activity light
9
USB Type-C port (10 Gbit/s data speed)
5
Audio-out (headphone)/Audio-in (microphone) combo jack
10
SD card reader (optional)
The audio-out (headphone)/audio-in (microphone) combo jack supports headphones, line output devices, microphones, line input devices, or CTIA-style headsets.
The USB port with HP Sleep and Charge provides current to charge a device such as a smart phone. The charging current is available whenever the power cord is connected to the system, even when the system is off.
The light on the power button is normally white when the power is on. If it is flashing red, there is a problem with the computer and it is displaying a diagnostic code. Refer to Interpreting system validation diagnostic front panel LEDs and audible codes to interpret the code.
Rear panel components
Figure : Identifying the rear panel components
1
Audio-out jack for powered audio devices
6
Audio-in jack
2
DisplayPort monitor connectors (2)
7
RJ-45 (network) jack
3
Optional port
8
Serial port (optional)
4
USB 3.1 Gen1 ports (2) (5 Gbit/s data speed)
9
USB 2.0 ports with wake from S4 (2)
5
USB 2.0 ports (2)
10
Power cord connector
When a graphics card is installed in one of the system board slots, the video connectors on the graphics card and/or the integrated graphics on the system board may be used. The specific graphics card installed and software configuration will determine the behavior.
The system board graphics can be disabled by changing settings in BIOS F10 Setup.
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available for use when contacting customer service for assistance.
Figure : Locating the serial number
