    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Spectre x360 - 13-aw0272no Product Specifications
8KG79EA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB LPDDR4-3200 SDRAM (onboard)
Video graphics
  • Intel® Iris® Plus Graphics
  • Integrated
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD IPS BrightView micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with anti-reflection Corning® Gorilla® Glass NBT™ (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 headphone/microphone combo
30.6 x 19.45 x 1.69 cm
1.3 kg
65 W USB Type-C™ power adapter
4-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 22 hours
Video Playback Battery life
Up to 14 hours
HP TrueVision HD IR Camera with integrated dual array digital microphone
BANG & OLUFSEN; Dual speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix (30-day free trial offer)
