    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP ZBook 17 G5 Mobile Workstation - Illustrated Parts
Computer major components
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Details about your computer, including model, serial number, product key, and length of warranty, are on the service tag at the bottom of your computer. See Labels for details.
Figure : Identifying the computer major components
Item
Component
Spare part number
(1)
Display assembly, non-touch, 17.3”
Non-TouchScreen display assemblies are spared at the subcomponent level only. For more display assembly spare part information, see Display assembly subcomponents.
Display assembly 17.3”
Touchscreen, UHD UWVA
L30407-001
Touchscreen, UHD UWVA, IR
L30408-001
Non-Touchscreen, UWVA DreamColor
L28468-001
Non-Touchscreen, UWVA DreamColor, IR
L28469-001
(2)
Keyboard
For a list of keyboard country codes, see Keyboard.
L28407-xxx
(3)
Power button board
L28466-001
(4)
SSD storage board
L30397-001
HDD storage board
L30396-001
(5)
Top cover
L30661-001
NFC antenna (not shown)
L30662-001
(6)
Smart card board
L14374-001
(7)
TouchPad
For use in models without DreamColor
L30663-001
For use in models with DreamColor
L31320-001
(8)
NFC module
L02249-001
(9)
Fingerprint reader (includes cable)
L28662-001
(10)
ODD
L31315-001
(11)
1 TB, SATA, 7200 RPM, RAW, 7 mm
L06427-850
2 TB, SATA, 5400 RPM, hybrid, 8 G, RAW, 7 mm
929167-850
1 TB, SATA, 5400 RPM, hybrid, 8 G, 7 mm
924036-850
2 TB, SATA, 5400 RPM, RAW, 7 mm, 2.5”
912487-850
500 GB, 7200 RPM, SATA, SED, RAW, 7 mm
820573-001
500 GB, 7200 RPM, SATA, FIPS, RAW, 7 mm
820572-001
500 GB, 5400 RPM, SATA, hybrid, RAW, 7 mm
732000-001
500 GB, 7200 RPM, 7 mm
703267-001
(12)
HDD bracket, part of the HDD hardware kit
L30394-001
(13)
HDD connector, part of the HDD hardware kit
L30394-001
(14)
Battery (6 cell 95 Wh 4.15 Ah LI )
L07044-855
(15)
SSD
1 TB, Z Turbo Drive
L28490-001
256 GB, Z Turbo Drive
L28491-001
512 GB, Z Turbo Drive
L28492-001
1 TB, SATA, TLC
L30762-001
256 GB, SATA, TLC
L30763-001
512 GB, PCIe, SS, NVMe, TLC
L28488-001
512 GB, PCIe, NVMe, Self-encrypting drive (SED), Opal 2, TLC
L28487-001
512 GB, SATA-3, FIPS-140–2, TLC
L28489-001
2 TB, PCIe, NVMe, TLC
L28486-001
256 GB, PCIe, SATA-3, SED, Opal2, TLC
L28485-001
256 GB, PCIe, NVMe, TLC
L28484-001
256 GB, NVMe SED, Opal 2, TLC
L28483-001
16 GB, IO
L28481-001
(16)
Speaker (includes cable)
L28477-001
(17)
WWAN module
Macan ME906S LTE with GPS M.2
845710-003
HP IT4210 LTE/HSPA+ with GPS M.2
L15398-001
(18)
Middle cover
L28471-001
(19)
Discrete MXM daughter card
AMD Radeon Pro WX 4170 4 GB
L30654-001
NVIDIA Quadro P1000 4 GB
L30655-001
NVIDIA Quadro P2000 4 GB
L30656-001
NVIDIA Quadro P3200 6 GB
L30657-001
NVIDIA Quadro P4200 8 GB
L30658-001
NVIDIA Quadro P5200 16 GB
L30659-001
(20)
Memory module (DDR-2400)
4 GB, 2666 MHz, 1.2 v, DDR4
L10598-850
8 GB, 2666 MHz, 1.2 v, DDR4
937236-850
16 GB, 2666 MHz, 1.2 v, DDR4
937438-850
16 GB, 2666 MHz, 1.2 v, DDR4, ECC
L24981-001
8 GB, 2666 MHz, 1.2 v, DDR4, ECC shared
L24983-001
(21)
System board (includes processor and replacement thermal material, see System board)
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating systems
xxxxxx-601: Windows operating system
Intel Core i5-8300H processor
L28459-xx1
Intel Core i5-8400H processor
L28460-xx1
Intel Core i7-8750H processor
L28461-xx1
Intel Core i7-8850H processor
L28462-xx1
Intel Xeon E-2176M processor
L28457-xx1
Intel Xeon E-2186M processor
L28458-xx1
(22)
RTC battery
L17255-001
(23)
Right fan, GPU
L30389-001
(24)
Left fan, CPU
L30388-001
(25)
Heat sink
For use in models with discrete graphics F16M memory
L30393-001
Heat sink
For use in models with discrete graphics N18P memory
L30391-001
Heat sink
For use in models with discrete graphics N18E memory
L30392-001
(26)
Heat sink
For use in models with UMA graphics
L30390-001
(27)
Service dover
L30395-001
Figure : Identifying the display subcomponents
Item
Component
Spare part number
(1)
Bezel
For use in models without a webcam
L30403-001
For use in models with an HD camera (includes camera shutter)
L30401-001
For use in models with an IR camera (includes camera shutter)
L30402-001
For use in models with an IR camera and backlight (includes camera shutter)
L31317-001
For use in models with an HD camera and backlight (includes camera shutter)
L31316-001
For use in models without a camera and backlight (includes camera shutter)
L31318-001
(2)
Webcam cover
L31319-001
(3)
Raw display panel, 17.3
FHD, AG, LED, UWVA
L30405-001
HD+ AG LED SVA
L30406-001
(4)
Hinges
L28464-001
(5)
Camera module
HD camera
L32738-001
IR camera
L32739-001
Microphone module (not shown; includes double-sided tape)
L34855-001
(6)
WWAN antenna, part of four antenna kit
L30400-001
(7)
WLAN antenna, part of four antenna kit
L30400-001
(8)
Display cable, includes cables and adhesive
L30404-001
(9)
DreamColor board, includes cable and adhesive
L31321-001
(10)
ALS sensor board
L30665-001
(11)
Display enclosure (includes tape, gasket, and foam)
L28463-001
Miscellaneous parts
Component
Spare part number
AC adapter 200 W PFC smart slim 4.5 mm
L00818-850
Adapter HP USB-C to VGA
831751-001
Adapter HP ZBook Thunderbolt 3 1 m cable
914966-001
Adapter HP USB-C to HDMI
831752-001
Adapter USB-C to DisplayPort
831753-001
Adapter USB to Gigabit RJ45
829941-001
Adapter HP HDMI to DVI
749038-001
Bracket kit, contains DDR shielding, ODD brackets, USB Type-C brackets, LCD connector brackets, and fingerprint reader brackets
L28479-001
Cable kit, for fingerprint reader, NFC module, and TouchPad
L28473-001
Cable lock, keyed 10 mm
840158-001
Cable lock, dual head keyed
840160-001
Essential Messenger
679922-001
Headset, stereo USB
840340-001
Mouse, comfort grip wireless
691922-001
Mouse, slim Bluetooth
746920-001
Mouse, HP USB laser
674318-001
Mylar kit
L34854-001
ODD bezel, with cable
L30398-001
Plastics kit, contains plastic placeholders for the fan, ODD, fingerprint reader, and SD card
L28480-001
Rubber kit, contains plastic placeholders for the fan, ODD, fingerprint reader, and SD card
L28476-001
Screw kit
L28478-001
