    Fix HP Printer issue on macOS
HP ProDesk 600 G4 Desktop Mini PC - Components
Standard configuration features
Features may vary depending on the model. For a complete listing of the hardware and software installed in the computer, run the diagnostic utility (included on some computer models only).
This computer model can be used in a tower orientation or a desktop orientation. The tower stand is sold separately.
Front panel components
Figure : Front panel components
Your computer model may look slightly different from the illustration in this section.
Item
Icon
Component
Item
Icon
Component
1
USB 3.1 Gen 2 Type-C port
5
Audio-out (headphone)/Audio-in (microphone) combo jack
2
USB 3.1 Gen 2 port*
6
Main storage LED
3
USB 3.1 Gen 1 charging port*
7
Dual-state power button
4
Headphone jack
*When the computer is on, the USB port connects a USB device, provides high-speed data transfer, and even when the computer is off, charges products such as a cell phone, camera, activity tracker, or smartwatch.
The main storage LED is normally white when the power is on. If it is flashing red, there is a problem with the computer and the main storage LED is displaying a diagnostic code.
Rear panel components
Figure : Rear panel components
Item
Icon
Component
Item
Icon
Component
1
Antenna cover
7
USB 3.1 Gen 2 ports (2)
2
Thumbscrew
8
Optional port
One of the following ports may be used: DisplayPort, HDMI, VGA, USB Type-C, or serial port
3
Security cable slot
9
USB 3.1 Gen 1 ports (2)
4
External antenna connector (optional)
10
RJ-45 (network) jack/status lights
5
Padlock loop
11
Power connector
6
Dual-Mode DisplayPort (2)
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available for use when contacting support for assistance.
Figure : Viewing the serial number location on the bottom of the computer
