    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Pavilion Gaming - 15-ec0053ax Product Specifications
9GD60PA
AMD Ryzen™ 5 3550H with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
Video graphics
  • AMD Radeon™ Vega 8 Graphics
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit, 300 nits, 72% NTSC (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo; 1 RJ-45
36 x 25.7 x 2.35 cm
Starting at 1.98 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
FreeDOS
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
