    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP ENVY - 13-aq1048tx Product Specifications
8TN44PA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
8 GB DDR4-2400 SDRAM (onboard)
1 TB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 headphone/microphone combo
30.7 x 21.15 x 1.47 cm
Starting at 1.17 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; iQiyi
