    Fix Windows 10 Update Issues
HP Z VR Backpack G1 Workstation - Components
Standard configuration features
Features may vary depending on the model. For support assistance and to learn more about the hardware and software installed on the computer model, run the HP Support Assistant utility.
Figure : HP Z VR Backpack G1 Workstation
Top components
Figure : Identifying the top panel components
Item
Component
(1)
Power button
(2)
DC out for VR headset
(3)
USB 3.0 Type-A ports (2)
(4)
HDMI 2.0 port
(5)
Mini DP, (DP 1.4 ready)
(6)
USB Type-C power connector and Thunderbolt port, 15 W, PCIe G3 x4
(7)
Audio out (headphone)/Audio-in (microphone) combo jack
Right (side) components
Figure : Identifying the right panel components
Item
Component
(1)
USB Type-C SuperSpeed ports (2)
(2)
Vent
Left components
Figure : Identifying the rear panel components
Item
Component
(1)
Vent
(2)
Power connector
Bottom
Figure : Identifying the bottom components
Item
Component
(1)
Left battery connector
(2)
Left docking port connector
(3)
Docking port
(4)
Right battery connector
