    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Z2 Tower G4 Workstation - Illustrated Parts
Computer major components
Figure : Identifying the major component components
Item
Component
(1)
Fan
(2)
3.5–inch hard drive
(3)
Drive cage
(4)
Access panel
(5)
Power supply
(6)
System board
(7)
USB Type-C module (select products only)
(8)
Front IO/User Interface (FIOUI) module
(9)
MicroSD memory card reader (select products only)
(10)
Chassis
(11)
Front bezel
System configuration specifications and differences can be found in the HP Z2 Tower G4 Workstation Quickspecs, located at http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=c05987463.
