    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Pavilion 15-bc542ur Product Specifications
8PP54EA
Intel® Core™ i5-9300H (2.4 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
38.24 x 25.25 x 2.45 cm
2.2 kg
150 W Smart AC power adapter
4-cell, 63.3 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours
Video Playback Battery life
Up to 8 hours and 45 minutes
FreeDOS 1.2
