HP Spectre x360 - 13-aw0009tu Product Specifications
8TJ11PA
Intel® Core™ i5-1035G4 (1.1 GHz base frequency, up to 3.7 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
8 GB LPDDR4-3200 SDRAM (onboard)
Video graphics
Intel® Iris® Plus Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 headphone/microphone combo
30.6 x 19.45 x 1.69 cm
Starting at 1.27 kg
65 W USB Type-C™ power adapter
4-cell, 60 Wh Li-ion polymer
HP TrueVision HD IR Camera with integrated dual array digital microphone
BANG & OLUFSEN; Dual speakers; HP Audio Boost 2.0
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; iQiyi; Express VPN (30 day free trial); LastPass password manager (30 day free trial)
