    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Spectre x360 - 15-df1112nc Product Specifications
8PN04EA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (onboard)
1 TB Intel® SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal 4K UWVA BrightView micro-edge AMOLED multitouch-enabled edge-to-edge glass with Corning® Gorilla® Glass NBT™ (3840 x 2160)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0b; 1 headphone/microphone combo
36.12 x 25 x 1.93 cm
2.12 kg
135 W Smart AC power adapter
6-cell, 84 Wh Li-ion polymer
Battery life mixed usage
Up to 9 hours and 30 minutes
Video Playback Battery life
Up to 10 hours and 45 minutes
BANG & OLUFSEN; Quad speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
