    Windows 11 Upgrade Guide
HP ProBook 440 G7 Notebook PC Specifications
Product image
Operating systems
Specification
Preinstalled
Windows 10 Pro 64 (National Academic only)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64
Windows 10 Pro (Windows 10 Enterprise available with a Volume Licensing Agreement)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-10510U processor
1.8 GHz base frequency, up to 4.9 GHz with Intel Turbo Boost Technology
8 MB L3 cache and 4 cores
Intel UHD Graphics 620
Intel Core i5-10210U processor
1.6 GHz base frequency, up to 4.2 GHz with Intel Turbo Boost Technology
6 MB L3 cache and 4 cores
Intel Core i3-10110U processor
2.1 GHz base frequency, up to 4.1 GHz with Intel Turbo Boost Technology
4 MB L3 cache and 2 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated
High-definition (HD) content is required to view high definition images.
Discrete
NVIDIA GeForce MX130 (2 GB DDR5 dedicated)
NVIDIA GeForce MX250 (2 GB DDR5 dedicated)
Supports HD decode, DX12, and HDMI 1.4b up to 4K at 30Hz.
Supports CUDA, Optimus, PhysX, and GPU Boost 2.0.
Specification
Non-touch
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare slim, 220 nits, 45% NTSC two WLAN antennas (1366 x 768)
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare slim, 220 nits, 45% NTSC for HD camera and two WLAN antennas (1366 x 768)
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare slim, 220 nits, 45% NTSC for HD and IR camera and two WLAN antennas (1366 x 768)
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare slim, 220 nits, 45% NTSC for HD camera, WWAN and two WLAN antennas (1366 x 768)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare slim, 250 nits, 45% NTSC and two WLAN antennas (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare slim, 250 nits, 45% NTSC for HD camera and two WLAN antennas (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare slim, 250 nits, 45% NTSC for HD and IR camera and two WLAN antennas (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare slim, 250 nits, 45% NTSC for HD camera, WWAN and two WLAN antennas (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP and PSR anti-glare flat with HP Sure View Integrated Privacy Screen, 1000 nits, 72% NTSC for HD camera and two WLAN antennas (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP and PSR anti-glare flat with HP Sure View Integrated Privacy Screen, 1000 nits, 72% NTSC for HD and IR camera and two WLAN antennas (1920 x 1080)
Touch
35.56 cm (14.0 in) diagonal FHD IPS eDP slim touch-on-panel screen, 250 nits, 45% NTSC for HD camera and two WLAN antennas (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP slim touch-on-panel screen, 250 nits, 45% NTSC for HD camera, WWAN and two WLAN antennas (1920 x 1080)
Sold separately or as an optional feature.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage/drives
Specification
Primary M.2 Solid State Drive storage
128 GB M.2 SATA TLC SSD
256 GB PCIe NVMe M.2 Value SSD
256 GB Intel PCIe NVMe QLC M.2 SSD with 16 GB Intel Optane memory H10
512 GB PCIe NVMe M.2 TLC SSD
512 GB PCIe NVMe M.2 Value SSD
512 GB Intel PCIe NVMe QLC M.2 SSD with 32 GB Intel Optane memory H10
Primary SATA Hard drives
1 TB 7200 RPM
1 TB 5400 RPM
500 GB 7200 RPM
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Specification
Standard
DDR4-PC4 SODIMMS
Supports dual-channel memory
(2) Dual-channel SODIMM slots (both slots are customer accessible/upgradable)
Runs at 2400 MT/s for Intel 8th generation processors
Configurations
32 GB DDR4-2666 SDRAM (16 GB x 2)
16 GB DDR4-2666 SDRAM (16 GB x 1)
12 GB DDR4-2666 SDRAM (8 GB x 1 and 4 GB x 1)
8 GB DDR4-2666 SDRAM (8 GB x 1)
8 GB DDR4-2666 SDRAM (4 GB x 2)
4 GB DDR4-2666 SDRAM (4 GB x 1)
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports/slots
Specification
Ports
(1) USB 3.1 Type-C Gen 1 connector (Power Delivery, DisplayPort)
(2) USB 3.1 Gen 1
(1) USB 2.0 (Powered port)
(1) HDMI 1.4b
(1) RJ-45/Ethernet port
(1) Headphone/microphone combo jack
(1) AC power port
(1) Standard security lock
HDMI cable sold separately.
Slot
(1) SD Card reader
Supports SD, SDHC, and SDXC.
Networking/communication
Specification
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 9560 802.11a/b/g/n/ac (2x2) WLAN and Bluetooth 5 Combo, non-vPro
Intel Dual Band Wi-Fi 6 AX201 802.11a/b/g/n/ac (2x2) WLAN and Bluetooth 5 Combo, non-vPro
Realtek 802.11ac (2x2) WLAN and Bluetooth 5 Combo
Wireless access point and internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
WWAN
Intel XMM 7360 LTE-Advanced (Cat9)
WWAN module requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds varies due to location, environment, network conditions, and other factors. 4G LTE not available on all products and all regions.
Ethernet
Realtek 10/100/1000 GbE NIC
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Specification
Audio
Integrated microphone (mono or dual-array)
(2) Integrated stereo speakers
Camera
720p HD and IR camera
720p HD camera
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
Spill-resistant with optional backlit function
Pointing device
Clickpad with multi-touch gesture support
Function keys
Function keys
F1 – Display switching
F2 – Blank or SureView On/Off
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Blank or backlight toggle
F10 – Num lock
F11 – Wi-Fi toggle
F12 – Sleep
Hidden functions
Fn+R - Break
Fn+S - System Rq
Fn+C - Scroll Lock
Software/security
Specification
BIOS
HP BIOSphere Gen5 (requires Intel 8th generation processors)
HP Sure Start Gen5 (requires Intel 8th generation processors)
BIOS Update via Network
Master Boot Record Security
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Hotkey Support - CMIT
HP Image Assistant
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft SCCM (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client Security software
HP Security Manager (including Credential Manager and HP Password Manager, and HP Spare Key)
HP Password Manager requires Internet Explorer or Chrome or Firefox. Some websites and applications might not be supported. User might need to enable or allow the add-on/extension in the internet browser.
HP Fingerprint Sensor (sold separately or as an optional feature)
Power On Authentication
Microsoft Defender (opt in and internet connection required for updates)
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP Client Security Manager Gen5
HP Fingerprint Reader (sold separately or as an optional feature)
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Secure Erase
Other standard security features
SATA 0 and 1 port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Integrated hood sensor
HP Sure Click
Support for chassis padlocks and cable lock devices
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Power
Specification
Power supply
Adapters
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 65 W USB Type-C adapter
HP Smart 45 W External AC power adapter
HP Smart 45 W USB Type-C adapter
Power cords
3-wire plug - 1 m (3.28 ft)
3-wire plug - 1.8 m (5.9 ft)
2-wire plug - 1 m (3.28 ft)
Duckhead power cord - 1 m (3.28 ft)
Duckhead power cord - 1.8 m (5.9 ft)
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 45 Wh Li-ion
Battery is internal and not replaceable by customer.
Physical specifications
Specification
Non-touch
Starting at 1.6 kg (3.53 lb)
Touch
Starting at 1.61 kg (3.54 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
32.42 x 23.77 x 1.80 cm (12.77 x 9.36 x 0.71 in)
