    Fix HP Printer issue on macOS
HP Notebook - 15-dw0009ca Product Specifications
6GH84UA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB cache, 2 cores)
Video graphics
Intel® UHD Graphics 600
1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD SVA micro-edge WLED-backlit touch screen (1366 x 768)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only, 5 Gb/s signaling rate); 1 AC smart pin
35.85 x 24.2 x 1.99 cm
1.77 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Stereo speakers
HP Audio Switch; HP JumpStart; HP Support Assistant; HP BIOS Protection
Pre-installed software
Netflix
