    Fix HP Printer issue on macOS
HP Pavilion - 15-cw1039au Product Specifications
8WM66PA
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate)
36.16 x 24.56 x 1.79 cm
Starting at 1.85 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY, dual speakers
HP Audio Switch; HP CoolSense; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings; HP BIOS Recovery
Pre-installed software
iQiyi; B&O Audio
