    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Pavilion - 14-ce3013nh Product Specifications
8BW75EA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Microprocessor Cache
ERROR123
Intel® Integrated SoC
Video graphics
ERROR123
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
32.68 x 22.55 x 1.79 cm
1.6 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Audio
ERROR123
B&O; Dual speakers; HP Audio Boost 1.0
Pre-installed software
ERROR123
