8AZ42PA
HP Gaming Pavilion - 17-cd0048tx
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
256 GB PCIe® NVMe™ M.2 SSD
17.3" diagonal FHD IPS anti-glare micro-edge WLED (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
40.5 x 28.2 x 2.5 cm
Starting at 2.74 kg
200 W AC power adapter
3-cell, 52.5 Wh Li-ion
- ${title}
- ${title}
- ${title}
- ${title}
HP Gaming Pavilion - 17-cd0048tx Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
