    Apache Log4j Update
HP Notebook - 15s-dy0001tu Product Specifications
6QG74PA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 600
256 GB M.2 SSD
15.6" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Realtek 802.11 a/b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 AC smart pin; 1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only)
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant
