    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP x360 - 11-ab103ne Product Specifications
6ZL44EA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 600
128 GB M.2 SSD
Optical drive
Optical drive not included
29.5 cm (11.6") diagonal HD SVA WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 (Data transfer only); 2 USB 2.0; 1 HDMI 1.4; 1 headphone/microphone combo
30.6 x 20.8 x 1.98 cm
1.4 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Video Playback Battery life
Up to 10 hours
HP Webcam with integrated digital microphone
Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
