    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
OMEN by HP 17-cb0016nm Product Specifications
7NA74EA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
Video graphics
  • Intel® UHD Graphics 630
  • Discrete
  • NVIDIA® GeForce RTX™ 2080 (8 GB GDDR6 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal FHD 144 Hz IPS anti-glare WLED-backlit (1920 x 1080)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
40.5 x 29.5 x 2.7 cm
3.32 kg
330 W AC power adapter
4-cell, 70 Wh Li-ion polymer
B&O; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
FreeDOS 1.2
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
