    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP ENVY X360 - 13-ar0082au Product Specifications
7WX96PA
AMD Ryzen™ 7 3700U with Radeon™ Vega 10 Graphics (2.3 GHz base clock, up to 4 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
16 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ RX Vega 10 Graphics
1 TB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 headphone/microphone combo
30.6 x 21.2 x 1.47 cm
Starting at 1.31 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost, HP Far-field Cortana support
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
