    Apache Log4j Update
HP Notebook - 15-db1224ng Product Specifications
7KE08EA
AMD Ryzen™ 3 3200U with Radeon™ Vega 3 Graphics (2.6 GHz base clock, up to 3.5 GHz max boost clock, 5 MB cache, 2 cores)
AMD Integrated SoC
Video graphics
AMD Radeon™ Vega 3 Graphics
256 GB M.2 SSD
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.8 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 45 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
