OMEN by HP 17-cb0012nc Product Specifications
7BK79EA
Intel® Core™ i9 9880H (2.3 GHz base frequency, up to 4.8 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 8 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
  • Two 512 GB PCIe® NVMe™ M.2 SSD
  • 2 TB 5400 rpm SATA
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal Full HD display
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
40.5 x 29.5 x 2.7 cm
3.31 kg
330 W AC power adapter
4-cell, 70 Wh Li-ion polymer
B&O; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
