    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Spectre x360 - 13-ap0014nn Product Specifications
7KH57EA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
1 microSD media card reader
2x USB Type-C™ 3.1 Gen 2 (Thunderbolt™ 3, DP 1.2, PD 3.0, Data transfer, HP Sleep and Charge ); 1x USB 3.1 Gen2 Type-A™ (HP Sleep and Charge); 1 headphone/microphone combo
30.88 x 21.79 x 1.45 cm
1.33 kg
65 W AC power adapter
4-cell, 61 Wh Li-ion
Battery life mixed usage
Up to 22 hours and 30 minutes
Video Playback Battery life
Up to 21 hours and 30 minutes
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP Connection Optimizer; HP JumpStart
