    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Pavilion x360 14-dh0007nv Product Specifications
7EE84EA
Intel® Core™ i3 8145U (2.1 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 620
128 GB M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Realtek RTL8821CE 802.11 b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
32.4 x 22.29 x 2.05 cm
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours and 15 minutes
Video Playback Battery life
Up to 8 hours
