    Fix HP Printer issue on macOS
HP LaserJet Pro M304, M305, M404, M405 - 13.10, 13.11, 13.13 jam error in the output bin
Use the following procedure to check for paper in all possible jam locations related to the output bin. When a jam occurs, the control panel displays one of the following messages:
  • 13.10.yz Paper is jammed in the output bin
  • 13.11.yz Paper is jammed in the output bin
  • 13.13.yz Paper is jammed in the output bin
  1. If paper is visible in the output bin, grasp the leading edge and remove it.
    Figure : Remove any paper from the output bin
  2. Press the front-door release button.
    Figure : Press the front-door release button
  3. Open the front door on the printer.
    Figure : Open the front door
  4. Open the rear door on the printer.
    Figure : Open the rear door
  5. Remove any jammed paper from the rear door area.
    Figure : Remove any jammed paper from inside the rear door
  6. Close the rear door and the front door on the printer.
    Figure : Close the rear door and front door
