Replace the toner cartridges if you receive a message on the printer, or if you have print quality problems.
- ${title}
- ${title}
- ${title}
- ${title}
HP Color LaserJet Pro M454, MFP M479 - Replace the toner cartridges
Toner cartridge information
Review details about ordering replacement toner cartridges.
The printer indicates when the toner cartridge level is low. The actual toner cartridge life remaining can vary. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
To purchase cartridges or check cartridge compatibility for the printer, go to HP SureSupply at www.hp.com/go/suresupply. Scroll to the bottom of the page and verify that the country/region is correct.
The printer uses four colors and has a different toner cartridge for each color: yellow (Y), magenta (M), cyan (C), and black (K). The toner cartridges are inside the front door.
caution:Cartridges are for distribution and use within their designated region only; they will not work outside of their designated region.
Item
Cartridge number
Part number
HP 414A Black Original LaserJet Toner Cartridge
Standard-capacity replacement black toner cartridge
414A
W2020A
HP 414A Cyan Original LaserJet Toner Cartridge
Standard-capacity replacement cyan toner cartridge
414A
W2021A
HP 414A Yellow Original LaserJet Toner Cartridge
Standard-capacity replacement yellow toner cartridge
414A
W2022A
HP 414A Magenta Original LaserJet Toner Cartridge
Standard-capacity replacement magenta toner cartridge
414A
W2023A
HP 414X High Yield Black Original LaserJet Toner Cartridge
High-capacity replacement black toner cartridge
414X
W2020X
HP 414X High Yield Cyan Original LaserJet Toner Cartridge
High-capacity replacement cyan toner cartridge
414X
W2021X
HP 414X High Yield Yellow Original LaserJet Toner Cartridge
High-capacity replacement yellow toner cartridge
414X
W2022X
HP 414X High Yield Magenta Original LaserJet Toner Cartridge
High-capacity replacement magenta toner cartridge
414X
W2023X
Item
Cartridge number
Part number
HP 415A Black Original LaserJet Toner Cartridge
415A
W2030A
HP 415A Cyan Original LaserJet Toner Cartridge
415A
W2031A
HP 415A Yellow Original LaserJet Toner Cartridge
415A
W2032A
HP 415A Magenta Original LaserJet Toner Cartridge
415A
W2033A
HP 415X High Yield Black Original LaserJet Toner Cartridge
415X
W2030X
HP 415X High Yield Cyan Original LaserJet Toner Cartridge
415X
W2031X
HP 415X High Yield Yellow Original LaserJet Toner Cartridge
415X
W2032X
HP 415X High Yield Magenta Original LaserJet Toner Cartridge
415X
W2033X
Item
Cartridge number
Part number
HP 416A Black Original LaserJet Toner Cartridge
416A
W2040A
HP 416A Cyan Original LaserJet Toner Cartridge
416A
W2041A
HP 416A Yellow Original LaserJet Toner Cartridge
416A
W2042A
HP 416A Magenta Original LaserJet Toner Cartridge
416A
W2043A
HP 416X High Yield Black Original LaserJet Toner Cartridge
416X
W2040X
HP 416X High Yield Cyan Original LaserJet Toner Cartridge
416X
W2041X
HP 416X High Yield Yellow Original LaserJet Toner Cartridge
416X
W2042X
HP 416X High Yield Magenta Original LaserJet Toner Cartridge
416X
W2043X
Do not remove the toner cartridge from its package until it is time to replace it.
caution:To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. If the toner cartridge must be removed from the printer for an extended period of time, place the cartridge in the original plastic packaging, or cover the cartridge with a lightweight opaque item.
The following illustration shows the toner cartridge components.
Toner cartridge components
Handle
Imaging drum
Memory chip
Figure : Toner cartridge components
caution:If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
note:Information about recycling used toner cartridges is in the toner cartridge box.
Remove and replace the toner cartridges
Follow these steps to replace the toner cartridge.
Open the front door by pressing the button on the left panel.Figure : Open front door
Grasp the blue handle on the toner cartridge drawer, and then pull out the drawer.Figure : Pull cartridge drawer out
Grasp the handle on the toner cartridge, and then pull the toner cartridge straight up to remove it.Figure : Pull up to remove the cartridge
Remove the new toner cartridge package from the box, and then pull the release tab on the packaging.Figure : Pull release tab on cartridge packaging
Remove the toner cartridge from the opened packaging shell. Place the used toner cartridge in the shell for recycling.Figure : Remove cartridge from opened packaging
Hold both ends of the toner cartridge and rock it 5-6 times.Figure : Shake the toner cartridge
Do not touch the imaging drum on the bottom of the toner cartridge. Fingerprints on the imaging drum can cause print-quality problems. Also, do not expose the cartridge to light unnecessarily.Figure : Avoid touching drum
Insert the new toner cartridge into the drawer. Make sure that the color chip on the cartridge matches the color chip on the drawer.Figure : Insert the new cartridge
Close the toner cartridge drawer.Figure : Push the cartridge drawer in
Close the front door.Figure : Close the front door
Pack the used toner cartridge into the box the new cartridge came in, or use a large cardboard box and fill it with several cartridges you need to recycle. See the enclosed recycling guide for information about recycling.In the US, a pre-paid shipping label is included in the box. In other countries/regions, go to www.hp.com/recycle to print a pre-paid shipping label.Adhere the pre-paid shipping label to the box, and return the used cartridge to HP for recycling.Figure : Pack and return the used cartridge
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
