OMEN by HP 15-dh0104tx Product Specifications
7NG82PA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
1 TB 7200 rpm SATA
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9560 (2x2) Wi-Fi® and Bluetooth® 5 Combo (Supporting gigabit file transfer speeds)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 headphone/microphone combo; 1 AC smart pin; 1 Mini DisplayPort™; 1 HDMI
36 x 26 x 2 cm
Starting at 2.4 kg
200 W AC power adapter
6-cell, 69 Wh Li-ion polymer
Bang & Olufsen; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
