    Apache Log4j Update
HP Stream - 14-ds0010nc Product Specifications
7JY38EA
AMD A4-9120e Dual-Core (1.5 GHz base clock, up to 2.2 GHz max boost clock, 1 MB cache)
AMD Integrated SoC
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R3 Graphics
64 GB eMMC
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS BrightView WLED-backlit (1920 x 1080)
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
33.7 x 22.5 x 1.86 cm
1.46 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Video Playback Battery life
Up to 8 hours and 15 minutes
HP Webcam with integrated digital microphone
Dual speakers
Windows 10 Home in S mode
HP 3D DriveGuard; HP CoolSense; HP JumpStart; HP Support Assistant
Office 365 Personal 1-year
