    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Chromebook - 15-de0500nd Product Specifications
6TA56EA
Intel® Core™ i5 8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2133 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
128 GB eMMC
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 7265 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge)
35.8 x 24.6 x 1.79 cm
1.81 kg
45 W AC power adapter
3-cell, 60 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours
B&O, dual speakers
Chrome OS™
