    Windows 11 Upgrade Guide
HP Notebook - 14s-dk0008ax Product Specifications
7DG00PA
AMD A9-9425 Dual-Core (3.1 GHz base frequency, up to 3.7 GHz burst frequency, 1 MB cache)
AMD Integrated SoC
4 GB DDR4-1866 SDRAM (1 x 4 GB)
1 TB 5400 rpm SATA
14" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ (Data transfer only, 5 Gb/s signaling rate); 1 AC smart pin; 2 USB 3.1 Gen 1 Type-A (Data Transfer Only)
32.4 x 22.59 x 1.99 cm
Starting at 1.47 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant
