    Windows 11 Upgrade Guide
HP Notebook - 15s-du0094tu Product Specifications
7NH61PA
Intel® Core™ i3-8145U (2.1 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Video graphics
Intel® UHD Graphics 620
1 TB 5400 rpm SATA
15.6" diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant
Microsoft Office Home & Student 2019
