Document ID: c06359491
Version: 1
HP EliteBook x360 1040 G5 Notebook PCs - F5 and F8 LED Keys Do Not Change to Amber When Pressed After Resetting the PC
Release date : 28-May-2019
Last updated : 28-May-2019
DESCRIPTION
The LEDs on the F5 and F8 keys do not turn to amber when they are pressed to mute the PC speakers and the internal microphone. The key functions work to mute the speaker, but the microphone mute function does not work when F8 is pressed. This occurs after resetting the PC and selecting the Remove everything option.
The computer should exhibit the following functions:
  • When F5 is pressed, the speakers should mute, and the LED should change to amber.
  • When F8 is pressed, the microphone should mute, and the LED should change to amber.
SCOPE
Computers:
Operating Systems:
Microsoft Windows 10 RS5 (Version 1809)
RESOLUTION
To recover from this issue, download and install the following SoftPaq to reinstall the audio driver.
SoftPaq Description
Release Notes
Download SoftPaq
Conexant HD Audio Driver 2017/2018
Version: 12.37.1.105
Revision: D
A more recent version of this software may be available. Check for newer versions at: http://www.hp.com/drivers
Hardware platforms affected : HP EliteBook x360 1040 G5 Notebook PC
Support Communication Cross Reference ID : IA06359491
