Replace the toner cartridge if you receive a message on the printer, or if you have print quality problems.
- ${title}
- ${title}
- ${title}
- ${title}
HP LaserJet Managed E50145 - Replace the toner cartridge
Cartridge information
This printer indicates when the toner cartridge level is low and very low. The actual toner cartridge life remaining can vary. Consider having a replacement cartridge available to install when print quality is no longer acceptable.
To purchase cartridges, contact your managed service representative. Make sure that you know your product model number, which appears on the product label on the back of the printer.
note:High-yield toner cartridges contain more toner than standard cartridges for increased page yield. For more information, go to www.hp.com/go/learnaboutsupplies.
Do not remove the toner cartridge from its package until it is time to replace it.
caution:To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover the green imaging drum if the toner cartridge must be removed from the printer for an extended period of time.
The following illustration shows the toner-cartridge components.
Toner-cartridge components
Memory chip
Imaging drumDo not touch the imaging drum. Fingerprints can cause print-quality problems.
Figure : Toner-cartridge components
caution:If toner gets on clothing, wipe it off by using a dry cloth and wash the clothes in cold water. Hot water sets toner into fabric.
note:Information about recycling used toner cartridges is in the toner-cartridge box.
Remove and replace the toner cartridge
Follow these steps to replace the toner cartridge in the printer.
Press the top-cover-release button on the left side of the printer.Figure : Press the release button
Open the front door.Figure : Open the front door
Grasp the handle of the used toner cartridge and pull out to remove it.Figure : Remove the toner cartridge
Remove the new toner cartridge from its protective shell by tearing off the plastic strip and opening the package. Save all packaging for recycling the used toner cartridge.Figure : New toner cartridge
Align the toner cartridge with its slot, and then insert the toner cartridge into the printer.Figure : Install the toner cartridge
Close the front door.Figure : Close the front door
Pack the used toner cartridge into the box that the new cartridge came in. See the enclosed recycling guide for information about recycling.In the U.S. and Canada, a pre-paid shipping label is included in the box. In other countries/regions, go to www.hp.com/recycle to print a pre-paid shipping label.Adhere the pre-paid shipping label to the box, and return the used cartridge to HP for recycling.Figure : Recycle the used cartridge
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
