    Apache Log4j Update
HP Color LaserJet Enterprise M751, HP Color LaserJet Managed E75245 - Load paper to Tray 1 (multipurpose tray)
The following information describes how to load paper into Tray 1. This tray holds up to 100 sheets of 75 g/m2 paper or 10 envelopes.
  1. Open Tray 1.
    Figure : Open Tray 1
  2. Pull out the tray extension to support the paper.
    Figure : Pull out the tray extension
  3. Use the blue adjustment latch to spread the paper guides to the correct size, and then load paper in the tray. For information about how to orient the paper, see Tray 1 paper orientation.
    Make sure that the paper fits under the fill line on the paper guides.
    The maximum stack height is 10 mm, or approximately 100 sheets of 75 g/m2 paper.
    Figure : Load paper
  4. Using the blue adjustment latch, adjust the side guides so that they lightly touch the paper stack, but do not bend it.
    Figure : Adjust the guides
Letterhead or preprinted - Portrait
Duplex mode
Paper size
How to load paper
1-sided printing
12x18, 11x17, RA3, SRA3, A3, 8K (273x394 mm), 8K (270x390 mm), 8K (260x368 mm), B4 (JIS), Legal, Oficio (8.5x13), Oficio (216x340 mm), SRA4, RA4, A4, Letter
Face-down
Bottom edge leading into the printer
1-sided printing
A4, Letter, Executive, A5, 16K (197x273 mm) 16K (195x270 mm), 16K (184x260 mm), B5 (JIS), Double Japan Postcard (148x200 mm)
Face-down
Left side of pre-printed image leading into the printer
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
Face-up
Top edge leading into the printer
Face-up
Right side of pre-printed image leading into the printer
Letterhead or preprinted -Landscape
Duplex mode
Paper size
How to load paper
1-sided printing
Face-down
1-sided printing
Face-down
Face-up
Right side of the pre-printed image leading into the printer
Face-up
Prepunched - Portrait
Duplex mode
Paper size
How to load paper
1-sided printing
Face-down
Holes toward the back of the printer
Face-up
Prepunched -Landscape
Duplex mode
Duplex mode
How to load paper
1-sided printing
Face-down
Holes away from the printer
Face-up
Holes towards the printer
Use Alternative Letterhead mode
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus:
  1. From the Home screen on the printer control panel, open the Settings menu.
  2. Open the following menus:
    1. Print
    2. Manage Trays
    3. Alternative Letterhead Mode
  3. Select On, and then press the OK button.
