![TracerI Chassis](/wcc-assets/document/images/233/c06125944.png)
Processor
TDP
Intel Core i9-9900 3.1 GHz Base frequency, 5 GHz with Intel Turbo Boost Technology, 16 MB cache, Octa core (Coffee Lake-R)
65 W
Intel Core i7-9700 3 GHz Base frequency, 4.7 GHz with Intel Turbo Boost Technology, 12 MB cache, Octa core (Coffee Lake-R)
65 W
Intel Core i7-9700F 3 GHz Base frequency, 4.7 GHz with Intel Turbo Boost Technology, 12 MB cache, Octa core (Coffee Lake-R)
65 W
Intel Core i5-9400 2.9 GHz Base frequency, 4.1 GHz with Intel Turbo Boost Technology, 9 MB cache, Hexa core (Coffee Lake-R)
65 W
Intel Core i5-9400F 2.9 GHz Base frequency, 4.1 GHz with Intel Turbo Boost Technology, 9 MB cache, Hexa core (Coffee Lake-R)
65 W
Intel Core i3-9100 3.6 GHz Base frequency, 4.2 GHz with Intel Turbo Boost Technology, 6 MB cache, Quad core (Coffee Lake-R)
65 W
Intel Core i7-8700 3.2 GHz Base frequency, 4.6 GHz with Intel Turbo Boost Technology, 12 MB cache, Hexa core (Coffee Lake-S)
65 W
Intel Core i7+ 8700 3.2 GHz Base frequency, 4.6 GHz with Intel Turbo Boost Technology, 12 MB cache, Hexa core (Coffee Lake-S)
65 W
Intel Core i5+ 8400 2.8 GHz Base frequency, 4.0 GHz with Intel Turbo Boost Technology, 9 MB cache, Hexa core (Coffee Lake-S)
65 W
Intel Core i5-8400 2.8 GHz Base frequency, 4.0 GHz with Intel Turbo Boost Technology, 9 MB cache, Hexa core (Coffee Lake-S)
65 W
Intel Core i3-8100 3.6 GHz Base frequency, 6 MB cache, Quad core (Coffee Lake-S)
65 W
note:32-bit systems cannot address a full 4.0 GB of memory.
note:Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
note:Not all ports support the highest resolutions.
note:Integrated video is not available if a graphics card is installed.
note:The motherboard supports 5.1 surround sound. If the computer does not have the required audio jacks for a 5.1 configuration, additional hardware is required to use 5.1 surround sound.
note:An internal speaker is not included with integrated audio. External speakers or headphones are required to hear sound.
note:Integrated audio is not available if a sound card is installed.
note:The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
note:HP provides basic support for software that comes with the computer. For in-depth feature assistance, refer to the help section in the software or on the software vendor's Web site.
Software Category
Software Title
Operating System
FreeDOS 1.2
note:This support document provides specifications and component images that reflect the original design intention for all PCs of this model. Under certain circumstances, a factory or service provider may install a component that meets or exceeds the listed specification and/or appears different than the image shown.
