    Fix Windows 10 Update Issues
    Are you working from home?
HP Gaming Pavilion - 15-cx0010ua Product Specifications
6VQ37EA
Intel® Core™ i5 8300H (2.3 GHz base frequency, up to 4 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
8 GB DDR4-2666 SDRAM (2 x 4 GB)
  • 128 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data transfer only, up to 5 Gb/s); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 headphone/microphone combo
36.5 x 25.65 x 2.54 cm
2.4 kg
200 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
FreeDOS 1.2
