    Apache Log4j Update
Document ID: c06305194
Version: 1
HP Z4 G4, Z6 G4, Z8 G4 Workstations - Critical BIOS Fix Resolving System Board Replacement
Release date : 22-Apr-2019
Last updated : 22-Apr-2019
DESCRIPTION
HP is releasing the following BIOS versions for the products listed below that will resolve workstation failures that result in the system board needing to be replaced. Some of the symptoms users may experience are No Power, No Display, and possible Beep Codes from the system.
-Z6 and Z8 G4 (P60 Family): BIOS version 2.18 has released to softpaq on hp.com in April 2019 and will be released for new factory builds on May 6th, 2019.
-Z4 G4 with Xeon Processor (P61 Family): BIOS version 1.75 has released to softpaq on hp.com in April 2019 and will be released for new factory builds on May 6th, 2019.
-Z4 G4 with Core-X Processor (P62 Family): BIOS version 1.75 has released to softpaq on hp.com in April 2019 and will be released for new factory builds on May 6th, 2019.
SCOPE
Systems:
  • HP Z4 G4 Workstation
  • HP Z6 G4 Workstation
  • HP Z8 G4 Workstation
Operating Systems:
  • Non-OS Specific
RESOLUTION
HP highly suggests updating your system(s) to the above BIOS versions or later under the "Description" section as soon as possible to alleviate possible system board replacement.
Hardware platforms affected : HP Z4 G4 Workstation, HP Z6 G4 Workstation, HP Z8 G4 Workstation
Support Communication Cross Reference ID : IA06305194
