    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 17-by1025ur Product Specifications
6PR51EA
Intel® Core™ i5 8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal HD+ SVA anti-glare WLED-backlit (1600 x 900)
Pointing device
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
41.48 x 27.22 x 2.45 cm
2.51 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours
Video Playback Battery life
Up to 10 hours
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 2.0
