    Fix Windows 10 Update Issues
    Are you working from home?
HP Pavilion - 17-ab499nk Product Specifications
4XZ92EA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
Intel® HM370
12 GB DDR4-2666 SDRAM (1 x 4 GB, 1 x 8 GB)
2 TB 5400 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo
41.6 x 27.95 x 2.99 cm
3.07 kg
135 W AC power adapter
6-cell, 62 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 9 hours
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
